549,881 active members*
2,336 visitors online*
Results 1 to 4 of 4
    Junior Member
    Sep 2013
    EZ-path 1 wiring for 240v 460v presently
    Hello, I recently purchased a 1996 EZ-PATH I from a trade school in Mass. The input voltage is wired for 460v. I want to change the input voltage to 240v 3 phase. There is a transformer in the top of the control panel that has input voltages listed on the front plate and specific wire and jumper locations. There is also a smaller transformer for the computer power supply which has volteges and locations specified. I don't want to burn up this machine and need some advice before proceeding. I don't know, Do I just put the wires in the specified locations and attach the 240 power or does the spindle motor also have to be rewired or replaced. I'm currently installing a 125amp sub panel and digital 20hp 3 phase converter. If anyone has experience with this situation please lend a helping hand. I would really appreciate it.
    Thank You: Stan Sawyer
    Sep 2010
    12
    I am currently doing the same thing. I have rewired the jumpers to the 230 v input on the transformers and the machine boots right up and homed out. The spindle motor however does not seem to be correct. It runs very slow. So now what, do I reach way in their and pull the electrical cover off the spindle motor and hopefully their will be a diagram.
    What did you end up doing?
    Sent from my SGH-T989 using Tapatalk 2
    Junior Member
    Sep 2015
    24
    Hi
    Just wondering if you did get this lathe sorted out?
    Im doing the same thing right now and would like to know what you wnded up doing.
    I used the transformer under the tailstock and wired for 240v in and 460 out but not sure qhat else to do.
    Any help would be greatly appreciated.
    Dec 2021
    Re: EZ-path 1 wiring for 240v 460v presently
    Does anyone have a schematic or pic of how to wire the transformer at tailstock. Panel on machine states 480 and all I have is 240 3 phase.
  1. Romi/Bridgeport EZ-Path Lathe serial transfer using EZ-Path Utilities
    By Moscow in forum Bridgeport / Romi Lathes
    Last Post: 06-04-2017, 04:37 AM
  2. 460V 60Hz Servomotor on 380V 50Hz
    By Jerre122 in forum Servo Motors / Drives
    Last Post: 08-01-2012, 11:11 PM
  3. What to do with a 460v 3-Phase Motor?
    By Mrs.B in forum Phase Converters
    Last Post: 04-26-2011, 12:20 AM
  4. Need Help! 5HP motor 460V to 230V?!
    By diyengineer in forum General CNC Machine Related Electronics
    Last Post: 10-25-2010, 12:08 PM
  5. Wiring Slo-Syn 240V 1 Phase Motors
    By PerPlexed in forum Servo Motors / Drives
    Last Post: 06-17-2009, 04:24 AM
