The download for Ezilathe we found does not have a install file.
Can someone please help.
Ezilathe does not need an install file, the directions are in the PDF.
If you extract to C:\Ezilathe directory (create manually), and then copy the the files from the sample directory (imperial or metric) to the same directory, It should work.
And yes it is checked out on Windows 10.
Hi Stu
I have down loaded Ezilathe but cannot instalL (Windows 10)
Have created folder in C drive named it Ezilathe unzipped and placed all files into folder.
error comes up C:\Ezilathe\Materialm.txt dose not exist..Please copy to C:\Ezilathe
Can you help
Ches
2 possibilities, You have downloaded the update version (Missing data files to avoid overwriting your data), or downloaded the full version, but not moved the required files to C:\Ezilathe. If the former, you will need to Download the full version (Keep the update .exe file, and copy it back to C:\Ezilathe.
Once the full version is downloaded, Copy all the datafiles from your choice (Metric or Imperial) directory directly into C:\Ezilathe. Both sample directories contain the Missing file + sample setup files to get you going, sample directories can be deleted at this point.
Ezilathe should now run in your choosen units, ready to customize to suit your needs.
If still no luck, then check the name of your directory it must be C:\Ezilathe.
Hope this helps. Another thread is also in this Forum, it has many questions and answers in it, It is one of the two "Sticky" threads listed at the top of this forum.
Thank You
Hi Stu I am working with Ezilathe
I have a CNC Lathe on which we turn wood.
I draw the profile design in Qcad and save as DXF This tool path I want to cut in both directions .
We have a Vee cutter which can cut up to depth of 24mm, this roughs out the shapeAttachment 481158
I hope you can see the attachment if not please email me on [email protected] I will send you DXF file
Also I need the G02 / G03 out put to be in X Z R how do we change this
I would be most grateful if you can help
Can the files be saved?
Regards
Ches
Ches
All is possible. Radius mode arcs can be easily added as an option but are generally not as reliable as center format. I Assume you have a controller other than Mach 3 or 4.
To add Radius format will require a program update, so not available immediately as other work in progress. Sent you an email.
