567,245 active members*
4,625 visitors online*
Thread: F360 G64 P Q
Results 1 to 5 of 5
    Feb 2011
    128
    F360 G64 P Q
    I have just found out that selecting G64 with PQ (or just P) retourning an error in TNG. PP is from their site ver. PlanetCNC 2.2
    Using just G64 have pass throu, some ideas...
    rgds
    Moderator
    Mar 2017
    1162
    Re: F360 G64 P Q
    G64 has optional P parameter, not Q.
    https://cnc.zone/gcode/gcodes/gcode-g64
    What error do you get and where?
    Aug 2020
    125
    Re: F360 G64 P Q
    Just change the smoothing in the post properties to "G64 with P"
    Its set to "G64 with PQ" by default, for whatever reason (most likely because the post is mainly the LinuxCNC post and nobody at autodesk made the effort to really test it with planetcnc ...)
    Feb 2011
    128
    Re: F360 G64 P Q
    Todaj I have simulation run with 3 diferent G64 code:
    - with just G64 - looks ok
    - with G64 & P - looks also ok
    - with both G64 P & Q - error come out ( att image)
    Attached Files Attached Files
    Feb 2011
    128
    Re: F360 G64 P Q
    Thank you ScorpionTDL, I have change to G64 only for now because is a simple object. Will go with your suggestion for 3D objects.
  1. F360 CAM training?
    By setlab in forum Autodesk CAM
    Last Post: 01-14-2023, 07:57 AM
  2. F360 & GRBL
    By DavidR8 in forum Arduino
    Last Post: 01-29-2021, 06:20 PM
  3. F360 Haning up this morning
    By smokediver576 in forum Autodesk CAM
    Last Post: 03-15-2017, 03:36 PM
  4. Need graphics card for f360
    By Cferrell84 in forum Desktops / Laptops
    Last Post: 07-20-2016, 05:05 AM
  5. g64 always with i and j
    By ch-performance in forum Philips
    Last Post: 06-06-2010, 09:02 PM
