585,764 active members*
4,144 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Face mill (?) to 1,5Kw ER20 spindle for aluminium planing
    Sep 2015
    43
    Hi
    Is there (affordable) options to get a nice surface finish on aluminium with these mentioned spindle details? (it is a Teknomotor)
    I am dreaming of an insert type face mill but honestly have 0 experience so maybe something else would be the best choise..?
    Should be cheap, less than a hundred euros.
    Flycutters look deadly
    thanks!
    Jun 2013
    443
    Re: Face mill (?) to 1,5Kw ER20 spindle for aluminium planing
    A bloke in Auckland NZ makes them. Custom size with welded inserts. So well made you can shave off 0.2mm at a time and the chips fly around the workshop like alloy flake snow.
    Sent from my SM-N970F using Tapatalk
    Jan 2005
    15362
    Quote Originally Posted by PropellerHat View Post
    Hi
    thanks!
    Shear Hog is about the only one that may work with your spindle for aluminum it would be a single insert, 3/4" diameter you would have to have the shank machined down to suit your largest collet size, they may do this for you plus cut the shank to the shortest you can use, the biggest problem you have is not a lot of motor torque so you can not go very big with the cutter diameter
    Mactec54
  1. 300mm Aluminium Face Mill for Sale
    By ashdhiman in forum For Sale Only
    Last Post: 03-02-2020, 03:22 PM
  2. Face mill for my spindle?
    By jonaorr in forum CNC Tooling
    Last Post: 07-18-2017, 02:42 AM
  3. Planing Aluminium (Newbie)
    By fraxinus in forum Chinese Machines
    Last Post: 04-24-2015, 04:49 PM
  4. Using a mill for shaping/planing?
    By Danny_guy in forum Uncategorised MetalWorking Machines
    Last Post: 03-18-2014, 08:33 PM
  5. Connecting face mill cutter into ER20 collet
    By spaltiel in forum DIY CNC Router Table Machines
    Last Post: 04-19-2013, 12:43 PM
