559,954 active members*
2,555 visitors online*
    Feb 2006
    9
    Fadal 4020 Not Aligning Cold Start
    The machine has run fine for the last month we have had it (bought used). We set the cold start and home in the same position for ease of use.
    Today the machine seems to want to find CS anywhere from .250 to .110 above the line. Any attempts to reset CS do not work, and I do not believe I have an easily adjustable resolver as the book shows. If I do turn the black top it will drop at least and inch at a time and throw me an error 18 or 23.
    Maybe the resolver itself is bad.
    Any thoughts??
    Jun 2022
    3
    Re: Fadal 4020 Not Aligning Cold Start
    Quote Originally Posted by homchz View Post
    Any thoughts??
    Did you ever fix this issue?
    I am currently having the same problem.
    -Brad
  1. FADAL VMC 4020
    By dmac88 in forum Fadal
    Last Post: 05-18-2009, 08:45 PM
  2. Fadal shuts down when cold?
    By Edster in forum Fadal
    Last Post: 11-23-2007, 08:52 AM
  3. How do I tell the age of a FADAL 4020?
    By Rickady in forum Fadal
    Last Post: 07-10-2007, 12:02 PM
  4. 904-1 cold start
    By yeepman2 in forum Fadal
    Last Post: 05-02-2006, 02:58 PM
  5. 4020 fadal cant get past "Cold Start"
    By chipsahoy in forum Fadal
    Last Post: 03-08-2006, 01:29 AM
