585,932 active members*
3,535 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 0TD Phase sequence - if I get it wrong what happens?
    Mar 2017
    98
    Hi I have a new lathe Fanuc 0-TD controller. As title suggests, if I flick the on switch and the phase sequence is wrong could I destroy the machine?
    I was going to turn on the mains power briefly, check the coolant pump rotation, and reverse if need be.
    Dec 2003
    24221
    Re: Fanuc 0TD Phase sequence - if I get it wrong what happens?
    Normally the machine will not power up if the phase rotation is wrong, until corrected.
    But IIRC the 0 controller itself does not require correct phase rotation as the earlier systems do.
    Only the 3ph motors external to the system.
    Albert E.
  1. Fanuc 0TD
    By PS85 in forum Fanuc
    Last Post: 10-13-2020, 12:46 AM
  2. error wrong PLC sequence in RAM
    By kallejojje in forum Controller & Computer Solutions
    Last Post: 10-09-2020, 09:25 PM
  3. Fanuc 0TD
    By PS85 in forum Haas Lathes
    Last Post: 10-08-2020, 03:52 PM
  4. Posting Toolpaths in WRONG SEQUENCE
    By fidia in forum BobCad-Cam
    Last Post: 11-12-2012, 04:03 PM
  5. Chuck indexing on a Fanuc 0TD..
    By patrickb in forum Fanuc
    Last Post: 09-04-2009, 01:02 PM
