600,838 active members*
3,390 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > FANUC 11M - How to enable G31? PS010 error / 9* parameter lockout?
    Hi everyone,
    I'm a beginner working with a Hitachi Seiki VA45 that uses FANUC 11M control, and I’m trying to use the G31 skip function for probing.
    I recently purchased a GP-800 touch probe, assuming the machine supported probing functions. Both the probe and the VA45 are currently functioning correctly.
    However, when I run G31 (e.g., G31 Z-1.0 F50), the machine triggers PS010, which suggests that G31 is not even recognized by the control.
    It turns out the previous operator didn’t fully understand the available control options, and from what I can tell, this machine likely came with very few (if any) optional features enabled.
    I suspect G31 is disabled through some 9*** parameter lockout, but there’s no documentation I can find about which one.
    If anyone knows which 9*** parameters control the availability of G31 on FANUC 11M, I’d be extremely grateful.
    Also, if you know about enabling G10, G37, or extended skip functions like G31.1, G31.2, G31.3, that would be very helpful as well.
    Thanks so much in advance!
    Apr 2009
    1391
    Re: FANUC 11M - How to enable G31? PS010 error / 9* parameter lockout?
    Send me an email [email protected]
  1. Parameter for using G68 on Fanuc 11M
    By 4thaxismachine in forum Fanuc
    Last Post: 09-21-2024, 09:32 AM
  2. Replies: 6
    Last Post: 02-18-2024, 03:11 PM
  3. Fanuc 11M parameter initiation step
    By jaredvj in forum Fanuc
    Last Post: 03-05-2020, 04:41 AM
  4. How to enable parameter write Fanuc 18i-WA
    By sontn in forum EDM Discussion General Topics
    Last Post: 12-18-2019, 03:13 PM
  5. Fanuc 11m parameter write protect
    By BrianM03 in forum Fanuc
    Last Post: 06-14-2010, 04:17 PM
