531,647 active members*
2,981 visitors online*
Results 1 to 9 of 9
    Oct 2007
    4
    Fanuc 16-im Alarm
    Hi, I have a Kitamura with a Fanuc 16-im controler. I got an alarm #2026 tool magazin servo battery low. I replaced the battery and can not get the alarm to clear. The servo amplifier has a u 11 blinking. Can not find this alarm in any of the many fanuc books. If anyone have any ideas, please email me at timmyjv@netzero.com. Thanks
    Sep 2008
    33
    I'm assuming this is a Beta drive??
    Found a gem of a web page here....GE Fanuc manuals in PDF.
    Here's the beta drive manual http://application.gefanuc.com/infol...ls/65245en.pdf
    U alarm on drive = power needs to be turned off and back on.
    11 alarm = motor needs to move 1 full revolution.
    Jan 2011
    I am having the same problem. I have replaced the batteries and I still have the Alarm 2026 tool magazine servo battery low. what do i need to do?
    Gold Member
    Mar 2003
    2930
    Quote Originally Posted by phix View Post
    I keep running into a dead end with that link... can you tell me what I'm doing wrong?
    Jan 2011
    I have this book.
    Give me you mail address.if you need.
    Mar 2007
    154
    Re: Fanuc 16-im Alarm
    It may be important to change the tool carousel drive (vigoservo) battery while the machine is still on so the machine does not lose its position. I keep spare batteries on hand for this purpose. They are 3.6V lithium batteries.
    If your battery died, it is possible that the vigoservo drive no longer knows the carousel's actual position. The drive normally displays the current carousel position on its display. See if the number on the drive matches your actual tool carousel position. If it doesn't you probably have Alarm 2025 now, not 2026.
    If the machine has lost its position, there is a procedure to go through to teach the vigoservo drive what the current actual magazine position is. Contact Kitamura's tech support - they have a "tech tip" document that steps you through the process.
    Dec 2009
    636
    here you go!
    good luck
    Nov 2015
    8
    Quote Originally Posted by zavateandu View Post
    here you go!
    good luck
    Hello there,
    I am having the 2025 alarm now , is this procedure ok on Fanuc 16i m , my machine is Kitamura mycenter 1xif
  1. Replies: 2
    Last Post: 11-24-2018, 09:15 PM
  2. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  3. Fanuc 6T-B alarm 402:servo Alarm
    By leiryll in forum Fanuc
    Last Post: 12-03-2013, 08:52 AM
  4. Replies: 0
    Last Post: 08-12-2013, 09:12 AM
  5. Replies: 6
    Last Post: 03-13-2013, 03:32 PM
