498,909 active members
6,236 visitors online
Results 1 to 5 of 5
    Oct 2010
    Fanuc 16TTA on Nakamura TW-10 Error 972
    Went to power up our nakamura tw-10 today and control will not boot it gets stuck on the initial screen and shows
    SYSTEM ALARM B103 - 18
    972 NMI OCCURRED IN OTHER MODULE
    SLOT 03
    913 RAM PARITY : (4N+3) <SUB
    i am wondering what to try, we had a ram parity error before and reloaded the entire system and it took about 6 month to get it up and running again. i am wondering lost or currupt parameters could causing the 972 error and if a complete re load will fix the machine. we have an rs232 backup but have lost the procedure to get this back in and going again. any help and or service manual for the 16T would be great its a 16-TTA control.
    Gold Member
    Aug 2011
    2517
    RAM Parity means you will have to clear the system and reload parameters (incl PMC parameters)
    with a correct and complete backup of everything the system can be restored in just a few minutes.
    follow this procedure as a starting point.....
    Fanuc 16 18 Memory Backup/ Restore Procedures
    Oct 2010
    Thanks, I am struggling to find any combination of IO channel and input device settings that will make the machine punch or read from the rs232 port
    Gold Member
    Aug 2011
    2517
    once the alarm is active you can't punch anything. only wipe everything and start from square one.
    or do you mean you have cleared memory, entered option parameters/ powered off/on and now can't get the
    RS232 working?
    Follow the set up on this page.....
    http://www.kfasllc.com/rs232_161821.htm
    Feb 2014
    11
    Dear experts,
    I need help to solve the below mentioned problem... My muratec mw-12 m/c Fanuc 16TTA Controller shown message after system booting PMC-RE SYSTEM FAULT NO=100-0 alram displayed when we power on the machine.... kindly give the suggestion... Thanks....
    Quote Originally Posted by fordav11 View Post
    RS232 working?
    Fanuc RS232 Fanuc 16 Fanuc 18 Fanuc 21 serial communication setup
  1. Nakamura-Tome TMC-2 Fanuc 3T
    By Leblondmakino in forum Fanuc
    Last Post: 06-10-2012, 06:29 PM
  2. Fanuc S6T - Nakamura TMC 4 -80
    By Jonne in forum Fanuc
    Last Post: 07-01-2009, 07:20 PM
  3. PROBLEM IN FANUC 18T-A NAKAMURA 20 II
    By Dragonbikes in forum Fanuc
    Last Post: 05-29-2009, 05:10 AM
  4. Fanuc 18T-A Parameters-Nakamura T.C.
    By JerryH in forum Fanuc
    Last Post: 07-02-2008, 12:42 PM
  5. FANUC-6T for NAKAMURA TMC-4
    By essafiwalid in forum Fanuc
    Last Post: 01-08-2008, 04:23 PM
