567,673 active members*
2,972 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 18M Will Not Startup After Grid Power Issue That Damaged Multiple Components !
Results 1 to 9 of 9
    Feb 2010
    16
    I have a Fanuc 18M controlled VMC that I have been chasing a trail of damaged components that I believe was caused by a grid power surge or spike, due to not only this machine but another machine and a couple Computer power supplies that were damaged over-night.
    I first replaced the Spindle Amp, a Servo Amp and PSU, after replacing, the CPU indicated that it could not startup up based on the Alarm LED's on the CPU ( Top 4 GREEN, Bottom Middle RED). I sent the CPU Board ( A16B-2201-0080) out for testing/repair with no result.
    So I replaced the CPU board with a new one, and used the Modules from the damaged unit. On-Startup I received the same Alarm LED's. I then replaced the processor module (A20B-2900-0930) & the spindle module (A20B-2900-0900) thinking that they may have been damaged.
    On start-up the CRT briefly flashes and that is about it. I have trolled through Forums and Maintenance manuals for more information with little luck. Any thought would be helpful.
    Is there a softkey combination or some other boot procedure that I can try with this unit ? I would like to take a hammer to it.
    (image attached of LED Alarm)
    Thanks.
    Apr 2009
    1321
    Re: Fanuc 18M Will Not Startup After Grid Power Issue That Damaged Multiple Component
    That is a 18A control. Any module could be damaged. Without either testing the modules on a known good control or replacing the cpu with another known good one (complete with good modules), you will have a tough time. Call me Monday 2893896117.
    Sep 2020
    4
    I have the same problem. Please help me
    Apr 2009
    1321
    Please tell us in detail what the problem is.
    Lütfen sonunu banada bildirin
    Neuer Benutzer
    Jan 2013
    425
    Quote Originally Posted by Fonzi View Post
    Thanks.
    Personally, I would disconnect everything external to the rack, leaving only the power supply and keyboard connections necessary to get the NC to power on. Then work my way through by connecting things in sequence. The "parts cannon" rarely works and is expensive.
    Neuer Benutzer
    Jan 2013
    425
    Thanks.
    LEDs indicate the system is stopped before the cpu is activated.
    Out of interest I'll investigate via the maintenance manual:-)
    If you have a back up try powering on while pressing 7 + 9 keys down. This deletes the memory which might be corrupt preventing CPU power on.
    Dec 2009
    851
    As far as i know pressing the 7+9 key will bring you in the IPL menu
    for deleting the sram data you have to keep pressing whie booting the RESET+DELETE keys
    After that you need the back up to restore or printed version to enter the data manual
    Good luck on this 1
    Apr 2009
    1321
    "As far as i know pressing the 7+9 key will bring you in the IPL menu" but only AFTER deleting all sram data; for IPL only, hold the 'period' and 'minus' keys while powering on.
  1. HAAS VF1 replaced battery now multiple alarms on startup
    By hebrewhammer8 in forum Haas Mills
    Last Post: 12-03-2013, 11:24 PM
  2. Replies: 0
    Last Post: 05-30-2013, 12:34 AM
  3. tied-to-grid 3 phase power generation
    By skippy in forum Phase Converters
    Last Post: 08-24-2008, 10:32 PM
  4. Fanuc 10TF Control Power Issue
    By rbleth51 in forum Fanuc
    Last Post: 08-20-2007, 08:22 PM
  5. Electricity isolated from power-grid?
    By medved in forum General Waterjet
    Last Post: 03-16-2006, 01:28 PM
