Having even more problems with my Fanuc 18MC on an Okuma and Howa Millac 438V. Right now the control boots up and I get +/- overtravel alarms on all axis, so it's stuck in emergency stop and won't let me do anything. At first I thought it was the 24VDC power supply, but that looks to be fine, along with all the fuses. Things I've looked at and tried so far
1. 24VDC power supply - tested fine
2. Fuses - all good
3. Emergency stop circuit - all good, closed loop end to end
4. I thought maybe NC parameters, so far have checked 9xxx and 3xxx NC parameters and all match my backup
5. I lost the timer and counter PMC parameters years ago before storage, but the machine was at least mostly functional for last few months that it has been plugged in
6. Controller - Y1000 NC control on bit is 0, so it's not coming on for some reason
The machine was working the night before, I did power cycle it a lot one evening earlier this week setting the axis home positions, and trying different settings, maybe 15-20 cycles, but it was fine until I came back the next morning. At this point I'm completely lost on what else to do or check. Perhaps it's a physical hardware issue? Or I'm missing something obvious? Any help or advice would be greatly appreciated!
