554,025 active members*
3,034 visitors online*
    Sep 2021
    3
    Fanuc 21-T dead rs232 comms
    Hello everyone
    I have a new to me Daewoo Lynx 200B lathe, I need some assistance in troubleshooting the RS232 Communications. The machine uses a Fanuc 21-T control.
    I would like to say I have tried absolutely everything under the sun to try and communicate with the machine but maybe I missed something.
    I have tried the following and a million combinations of Baud rates, parity, stop bits, flow control, cables, com ports, software etc.
    I cannot send or receive a single byte of information between the cnc and my pc.
    My setup is a usb to serial db9 cable that I have confirmed works by using it to send files to and from a different machine. I then use a custom made db9-db25 rs 232 cable that again has been confirmed to work.
    When I try to send files to the CNC, the leds on the usb serial cable blink indicating transfer is occuring but I dont believe that any data is being recorded by the cnc control. The menu on the Fanuc display blinks LSK like its waiting for data but nothing comes through. I have also tried sending a file from the machine to the control but again nothing comes through. It seems to me that the Fanuc board may just be toast. - as far as I know this machine came out of a running cnc shop.
    Any suggestions?
    Sep 2021
    3
    Re: Fanuc 21-T dead rs232 comms
    If it helps anyone in the future.
    I discovered that I needed to have my cable cross pins 2 and 3 instead of 2-2 and 3-3.
    No idea why this machine is this way. But I can now send files to and from.
    Mar 2015
    36
    Greetings,
    Your solution brings a FlashBack to me.
    Years ago I had a flatbed plotter that used a "Null" Modem cable.
    I bought a box of connectors and a crimp tool to make my own cables.
    Like you, I do not know the electronics well enough.
    Cheers,
    Dave
    Apr 2011
    823
    Quote Originally Posted by Jeremy_Sawatzky View Post
    Because pin 2 is send data and pin 3 is receive data. You were trying to send to a "send" signal.
