547,590 active members*
2,493 visitors online*
Results 1 to 4 of 4
    Junior Member
    Aug 2018
    5
    Fanuc 21-t error 414 servo alarm
    Hello....I have problems with the control of my fanuc 21-t lathe.
    I would like to know if you can advise me because in my small country there is no fanuc specialist technician....
    ¡¡¡¡¡¡thank you very much!!!!!!
    data: sometimes when you leave the lathe on for 30 minutes or 1 hour with this error when you turn it off and turn on the lathe again the error disappears but then when you run the g code in automatic mode it works for a few minutes and then the lathe stops and the error 414 servo alarm appears again....
    Alarm code: 1 on fanuc servo drive A06B-6079
    On the lathe control panel : 414 servo alarm : x axis detec err
    414 servo alarm : axis detec err
    Any advice on what it could be?
    Dec 2009
    689
    Re: Fanuc 21-t error 414 servo alarm
    post a picture with diagnose 200 but i am guessing is the internal fan problem,take it out and clean it or change it
    Junior Member
    Aug 2018
    5
    thanks for answering my friend...
    the fan works I look at it and is spinning I pass the photo with the ddiagnostico 200
    Dec 2009
    689
    the EXP alarm is related to encoders
    as i checked my info i see there are 2 fans mounted on that driver.
    did you plugged out the control PCB to check if is any fan on the PCB?
  1. Replies: 26
    Last Post: 06-02-2020, 04:11 PM
  2. Replies: 1
    Last Post: 04-10-2017, 05:01 AM
  3. Error 414 Z-axis error detect servo alarm
    By andywids in forum Uncategorised MetalWorking Machines
    Last Post: 07-09-2009, 03:56 PM
