555,184 active members*
1,734 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 21i-T 1001 Spindle Alarm in a Colchester Tornado A50 Lathe
Results 1 to 1 of 1
    Aug 2021
    Hi all,
    I have a Tornado A50 2-axis lathe with a 21i-T controller. For the most part it’s been smooth sailing since buying it from new. Last week, it had been running fine all morning and all of a sudden, after pressing cycle start, it started fine, but 5 seconds in, it alarmed out with “1001 SPINDLE MONITOR OFF WHEN COMMAND”.
    I could press reset and the alarm disappeared, rewind the program and start again, but the same thing happens. The spindle will start up, but alarm out after a few seconds. All axes work fine. I’ve put it into MDI mode and just given it the command to spindle start, to see if it alarms out and it does within 5 or so seconds. No other alarms or errors. I’ve shut the machine down for half an hour and restarted it, and it boots up fine without any alarms or errors as it normally does. But alarms out as soon as the spindle starts. The belt that runs from the spindle to the small encoder box is intact (hoping that it may have just thrown a belt).
    Has anyone encountered this before? Any advice or suggestions would be greatly appreciated.
    Cheers.
    Attached Thumbnails Attached Thumbnails A0071FFC-8F1F-4776-82F7-0C1EE5E77E18.jpg
    Apr 2011
    815
    Re: Fanuc 21i-T 1001 Spindle Alarm in a Colchester Tornado A50 Lathe
    This alarm is being driven from the PMC ladder. You will have to see which A coil is active and search that coil in the ladder to find out why.
