541,041 active members*
3,868 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 21iT Aggressive Spindle Drive?
Results 1 to 1 of 1
    Jan 2021
    I recently purchased a Clausing Colchester CNC lathe with a 21iT control.
    When the spindle starts or changes speeds it is very aggressive, Pulls 160+ amps.
    Dims the lights and will fault out frequently
    Machine is rated for Max 100amps and the wiring was sized for 175amps
    Spindle drive motor has been checked and is within spec.
    I have talked to Clausing and they have never adjusted Fanuc spindle drive parameters on any lathe.
    Don't misunderstand me, Clausing Industrial CNC service guys in Kalamazoo MI are the best and have helped me over the years more than I deserve.
    Fanuc says they need to come out$$$$$$$$$$$$$$$$$$$
    I don't mind paying but Fanuc tech wants a blank check
    There must be some parameters that control the spindle max amp/load/ramp up?
    Have no idea if someone has altered the parameters?
    This is a nice machine and have a lot of time and money invested trying to fix this one issue.
    Any thoughts or who I can contact?
    Apr 2011
    738
    Re: Fanuc 21iT Aggressive Spindle Drive?
    ACCEL/DECEL time is too short?
    Check the setting of parameter 4082, set in milli-seconds.
    Oct 2009
    291
    Quote Originally Posted by Lethal View Post
    Do you know the spindle amplifier part number ?
    What alarm are you getting?
    regards
    AlexFanuc
    May 2016
    500
    What model of Clausing is it ?
