Hello All,
I'm wondering if anyone out there uses parameter 10000-10200 to set limits on tool geometry and tool wear offsets? Using these parameters, a range can be set for geometry, wear, radius, etc of each tool, so that a user is restricted from making changes outside the range that is set. Does anyone use this?
For example, I can set a range for tool 1 'X' Geometry of 121.000-121.500. If someone tries to change it to 121.600, a message pops up saying data is out of range. Any reason why I wouldn't want to do this? Thanks!
