545,780 active members*
2,263 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 32i Way lube Lubrication time settings
    May 2018
    15
    hi i am wondering if you guys know how to set the timer or check for timer? ? i feel like my machine (DMG DMC 2035v) is not lubricating at intervals. it's supposed to be around every 20 seconds ?? or 60 seconds?
    can someone post their setting i can perhaps copy? i know it's the PMC page with T00000 ?? ?
    Apr 2011
    775
    Re: Fanuc 32i Way lube Lubrication time settings
    Can you post your ladder?
    May 2018
    15
    Quote Originally Posted by drdos View Post
    so i figured out the time for how long the pump should be pumping grease but i can't get the machine to do this at intervals yeah ?
    can we download images from instagram
  1. Fanuc O-md Lube Time Alarm!!!!
    By sco999 in forum Fanuc
    Last Post: 09-16-2018, 05:59 PM
  2. Leadscrew lubrication/lube
    By piperpilot in forum DIY CNC Router Table Machines
    Last Post: 11-15-2012, 10:40 AM
