600,986 active members*
2,651 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 410 'excess' error mystery, not usual suspects
Results 1 to 9 of 9
    Jan 2011
    An axis in my machine throws up this error, you would think it's mechanical but the mystery deepens as things are ruled out. It's done this before but mysteriously was fine after sending the servo drive to be repaired and reinstalling it because it checked good. Now it's happening again.
    When moving the X axis with the handwheel or jog, it will move a little and then stop which causes the 410 or 411 "servo alarm: X axis excess error".
    When in rapid it will move much more but sounds very loud and coarse.
    So it sounds like it must be mechanical drag or a motor or encoder.
    If I swap the X and Y motor leads and encoder (at the servo drive), the other axis then is the one that behaves the same way while the original axis is now slooth so that rules out mechanical drag and motors.
    At that point I sent the Fanuc drive out but it checked out OK. When I put it back in everything worked fine.
    Now it's happening again, does anyone have any ideas?
    BTW, the machine is an Excel VMC with Fanuc 21mb control. The Servo drive is an A06B-6080-H304
    When the error pops up, there is no error code on the servo drive and the reset button will restore it immediately.
    Thank you
    Jan 2011
    Well, I can isolate it to one channel in the Fanuc unit and can't think of anything else beside sending it out for repair and hoping something is found.
    Apr 2009
    1391
    why can't it be in the control? I am thinking encoder and axis control circuitry.
    Jan 2011
    Quote Originally Posted by memoryman View Post
    When I switched the connectors from the control (and left motor and encoder connections in place), it then showed the other axis as the problem on the CRT.
    I *think* that ruled out the control.
    Apr 2009
    1391
    did not realise you had tried that. I agree, that ruled out the control.
    Excess error has usually means that the control did not detect sufficient movement (given the values in parameters). Sounds like the servo drive is intermittent.
    Aug 2018
    13
    Re: Fanuc 410 'excess' error mystery, not usual suspects
    Quote Originally Posted by Barbapapa View Post
    Thank you
    Hello, I am presenting the same problem on my machine.
    Just like you, I exchanged the Y axis with the X axis to rule out a problem in the motor and the cable, and now the error appears in the other axis.
    It seems that it was from the output of the drive but we also changed a gate that seemed not to work and even so the error persists.
    Could you tell me how you solved this alarm? Your help would be very helpful. Thanks.
    Jan 2013
    474
    Thank you
    I had similar problems on a fanuc alpha (redcap) motor, it sounded like a bag of nails and I changed the motor under warranty, problem was fixed.
    I suspect the motor demagnetised or had a problem with a field magnet.
    Aug 2018
    13
    In my case it is not the motor or the cable, because we exchange the Y axis with the X axis and at that moment it works. It seems that it was from the exit on the drive.
    Mar 2025
    bro did you solve this problem? can you give me any idea. I have this problem too
  1. X Axis Excess Error
    By Ahmed18 in forum Fanuc
    Last Post: 12-19-2013, 10:15 AM
  2. 431 z axis servo excess error
    By bassackwards142 in forum Fanuc
    Last Post: 06-25-2013, 02:46 AM
  3. Yaskawa Servopack error: A.D1. Motor Load Position Excess Error
    By Syphonics in forum Servo Motors / Drives
    Last Post: 04-26-2012, 07:53 AM
  4. Alarm 410 V axis Excess Error, FIX?
    By D_Flannery in forum Fanuc
    Last Post: 01-14-2011, 05:13 AM
  5. Fanuc 21i 411 excess error
    By ceilingwalker in forum Servo Drives
    Last Post: 03-18-2010, 06:55 PM
