548,544 active members*
1,685 visitors online*
Results 1 to 7 of 7
    Aug 2010
    Fanuc 5M parameter tape??
    Hello all,
    I have a apotential Sword of Damocles hanging over one of my machines. It is a Hitchi seiki minimatic 500 with a Fanuc 5M control.
    I have religeously replaced the batteries on the memory over the years, and all has gone well so far. But, I can no longer find the parameter loading tape for this machine. I have all of the parameters written down and recorded.
    According to myth, the first set of 3 to six parameters can only be loaded by a convoluted tape ritual.
    A couple of questions. I am using a refresh your memory setup on the tape reader port for inputting code anyway. could this be used to input the parameter data? ( I would need to know the data format to write the code to simulate the tape.)
    Or is there a manual way to input this data without the need for the tape reader and small animal sacrifice??
    any help would be most appreciated!
    thank you,
    arnie
    fanuc 5t format parameter tape
    These images may help with format parameters
    Attached Thumbnails Attached Thumbnails fanuc5t procedure GERMAN11.jpg   fanuc5t procedure GERMAN12.jpg   fanuc5t procedure GERMAN13.jpg
    Aug 2010
    Smile 5m cmos perameter format
    Thank you!
    My sister speaks german, and I can decipher quite a bit as well. This should help me code a work around.
    all the best!
    arnie
    Do you have the first paper tape of the program to initialize? This initial paper tape preparation system that could be put parameters (see under Section E and F).
    May 2010
    15
    I have the same problem - I have a Howa lathe with Fanuc 5T controller and cannot get the first 3 parameters in.
    I do not have the "magic" tape but will try with a file containing the code shown in the pages in this thread sent via a tape converter (like a BTR box). But, I cannot read the pages very well - the B and the 8 look similar, so should the first part of the tape read 2B85%80%%0806, or 2885%...
    Also, is it possible to have the whole set of parameters (about 30-40) on a tape in this format ?
    Chris
    solve the problems to enter parameter
    We solve this problem. We made a programmer for the 6508 RAM memory and an small adapter pcb for the memory with lithium batteries. If you have free RAM memory chip and a table of parameters we can to help .Send me your e-mail to send you a picture in better resolution
    Sep 2021
    3
    Re: fanuc 5t format parameter tape
    Do you have an English version of this document?
  1. fanuc tape cut-mate parameter lost
    By aidinjoon in forum Fanuc
    Last Post: 06-08-2021, 07:44 PM
  2. Replies: 2
    Last Post: 01-26-2014, 03:56 PM
  3. Parameter Tape
    By scoopie80 in forum Want To Buy...Need help!
    Last Post: 01-31-2013, 04:36 PM
  4. Parameter List or MSD tape for rent or sale
    By Zahnrad Kopf in forum EMCO Lathe
    Last Post: 09-27-2012, 01:51 AM
  5. daewoo puma 12lb tape format problem/parameter problem
    By robb12877 in forum Daewoo/Doosan
    Last Post: 08-25-2011, 06:13 AM
