600,986 active members*
2,819 visitors online*
Results 1 to 1 of 1
    Feb 2023
    6
    Fanuc Alarm 920
    Hi All
    I have a Fanuc wire edm with a 16-wa controller that has come up with a 920 alarm as per the picture attached. From what I can see in the manual it’s an issue with of the axis control cards (it has) but can anyone guide me as to which one I should change or is it just swap each one until the fault doesn’t happen again. Also can I remove the fs16/18 board without losing parameters? I don’t have a sram backup as it always comes up with a parity error when I try to do it. This has been an issue for years but the machine has worked fine. Appreciate any advice.
