after some help diagnosing a fault on a Fanuc AC spindle drive in a old OKUMA LB 15.
Anyone ? care to have ago
I posted this on the okuma section without any replies , Thought id try here as its fanuc
SDU Alarm on Okuma LB15 it has fanuc drive
AC Spindle Drive A06B-6044-H018
Fault code NUMBERS 1 2 8
Book indicates Voltage at the DC capacitor has risen abnormally
Voltages measure on the circuit board were all ok except the +24 volt which showed 27.8 volts ??
All fuses are ok
I have turned the machine off a few times with rest periods with rest periods in-between but still the error comes up when the computer comes on.
