525,618 active members*
2,482 visitors online*
Results 1 to 9 of 9
    Oct 2007
    4
    Fanuc EDM Alpha-OC Reference Return
    Hi all,
    I am learning to use my recently acquired 1998 Fanuc Robocut Alpha-OC, and am stumped !!
    After having read the entire operators manual, I am still unable to zero the axes to get the system moving under program control.
    Please someone tell me how to do a reference return.
    All help is appreciated.
    Nov 2011
    12
    hi Frinkdaddy1
    check the maintenance manual Sect II Part 7 "setting the machine zero point"
    Oct 2007
    4
    Thank you sir, that's exactly what I did last night. Apparently the servo pulse coders lost power at some point in time and forgot the reference point coordinates.
    I should have the machine up and running tonight. Initially when I thought reference return, I was thinking Fanuc OT and was looking for a (ref) button to push.
    Regards,
    F1
    Oct 2010
    8
    Re: Fanuc EDM Alpha-OC Reference Return
    Quote Originally Posted by frinkdaddy1 View Post
    Regards,
    F1
    I'm assuming you figured this out, but I have a printout I got from Methods Machine that gives step by step directions on how to do the reference return. If this would help anyone out I can scan them and upload.
    Oct 2007
    4
    Hello wdevine,
    I did finally figure it out, after reading the Fanuc manual about twenty times.
    It seems that something is lost in the translation from Japanese to English.
    I would be very interested in Methods' translation, just for my own records.
    Thanks,
    F1
    Oct 2010
    8
    Ask, and ye shall receive. PDF should be attached.
    Attached Thumbnails Attached Thumbnails FANUC HOME SET.PDF
    Oct 2007
    4
    Fantastic,
    So much easier to understand.
    Thanks so much.
    Jul 2015
    Dear frinkdaddy1!
    What diameter is the adjustment nozzle? I read the Method document, and i don't see the diameter of the adjustment nozzle.
    tibi1
    Feb 2020
    Hello,
    I've made a mistake and I set the machine coordinate in the lowest point and now i cannot move it on Z+. How I can change the absolute coordinate to 0?
  1. Fanuc Zero Reference Return Problems?
    By grege101 in forum Fanuc
    Last Post: 12-05-2017, 10:08 PM
  2. Adjust Reference Position Return - 10M
    By Swemill in forum Fanuc
    Last Post: 09-28-2011, 04:03 AM
  3. Reference return incomplete
    By Leha_Blin in forum Fanuc
    Last Post: 08-17-2011, 04:22 AM
  4. G30(reference point return)
    By Reg wharton in forum Daewoo/Doosan
    Last Post: 06-13-2008, 11:32 AM
  5. Return through reference point?
    By RBrandes in forum Haas Mills
    Last Post: 12-02-2005, 04:49 PM
