585,938 active members*
3,237 visitors online*
Thread: Fanuc G92
    Mar 2006
    92
    Fanuc G92
    Why doesn't this G92 not work? Fanuc Series 2iTB controller.
    I'm thinking a thread parameter change.
    it gets here
    G0 G54 X3.071 Z.2 M8
    Then it just goes home.
    O0001
    (PROGRAM NAME - BOX)
    (DATE=DD-MM-YY - 21-0ZONTAL\C1-120 CARRIER\CI)
    (NC FILE - R:\OPER HORIZONTAL\C1-120-61203 DF SCALLOPE)
    (MATERIAL - STEEL INCH - 1030 - 200 BHN)
    G20
    (TOOL - 3 OFFSET - 3)
    (OD THREAD RIGHT INSERT - NONE)
    G0 T0303
    G18
    G97 S450 M03
    G92 X2.8571 Z-1.6 F.125
    X2.8449
    X2.834
    X2.8241
    X2.8149
    X2.8062
    X2.798
    X2.7903
    X2.7829
    X2.7758
    X2.769
    X2.769
    G0 X3.071
    M9
    G28 U0. W0. M05
    T0300
    M30
    Nov 2018
    26
    Re: Fanuc G92
    You have three types A,B,C for lathe @Fanuc.
    This Gcode can be different, based on which type your controller is set.
    It can be changed in PLC
  1. Replies: 10
    Last Post: 09-01-2022, 04:04 AM
  2. Change from G92 to G50 Coordinate System Fanuc 6T
    By hybridintl in forum Turning
    Last Post: 05-19-2020, 04:01 PM
  3. Fanuc 16i tool offsets, g92, etc...
    By peterson76 in forum Fanuc
    Last Post: 07-23-2013, 03:37 PM
  4. G92
    By jybute in forum Haas Mills
    Last Post: 05-26-2013, 03:27 AM
  5. G50 or G92?
    By protrxrptr17 in forum G-Code Programing
    Last Post: 01-07-2007, 03:25 AM
