587,267 active members*
3,271 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc O-TT Alarm: 522 OVER TRAVEL : +Z
    Sep 2023
    Hey All,
    I have a SST-16 Swiss Lathe Machine with Fanuc O-TT. My sub-spindle suddenly stopped working and this alarm message appear : 522 OVER TRAVEL : +Z.
    When I use JOG, It moves backward until it reaches the end. But when I try to move it forward, It moves for like 1/16th of an inch (1 mm) then the alarm message appear : 522 OVER TRAVEL : +Z
    The parameters are the same. I have no idea what is happening.
    May 2024
    9
    Re: Fanuc O-TT Alarm: 522 OVER TRAVEL : +Z
    It sounds like your SST-16 Swiss Lathe is having a limit switch issue or there's an obstruction causing the sub-spindle to think it's over-traveling.
    Nov 2007
    364
    Estop and P cancel the machine at power up and see if it goes away ------------For some reason its looking for home
  1. 1012 over travel alarm in fanuc series.
    By udhay in forum Fanuc
    Last Post: 07-27-2020, 06:05 PM
  2. Fanuc Series O-T over travel alarm
    By lectriceng in forum Fanuc
    Last Post: 11-07-2017, 07:41 PM
  3. Fanuc 11m OT008 -y axis over travel alarm
    By cjfisher in forum Fanuc
    Last Post: 10-10-2013, 10:28 PM
  4. Fanuc 506 and 507 Over travel Alarm
    By robertox in forum Fanuc
    Last Post: 08-28-2010, 11:09 PM
  5. Fanuc O-M controller - 522 T/M6 error
    By e_stroud in forum Fanuc
    Last Post: 03-17-2008, 05:29 PM
