592,217 active members*
4,353 visitors online*
    Sep 2019
    12
    Fanuc OiF and linear scale
    I see that the OiF controls have inputs for linear encoders through the Separate Detector Unit. Would it be possible to use these to compensate for backlash more efficiently?
    Dec 2009
    1003
    Re: Fanuc OiF and linear scale
    Exactly for that purpose were designed.
    Sep 2024
    9
    In case of poor mechanical condition, scales will not help to much.There may be too great discrepancies between two separated measurement systems. Make up your mechanics, bearings, ballscrews, linear or box ways, geometry set backlash value and proper acceleratoon of them and look is a large expense on scales justified or not. I would start from here.
  1. Replies: 7
    Last Post: 07-20-2022, 09:12 PM
  2. How to interface linear scale with fanuc CNC controller, Please help.??
    By Nsfpcp in forum CNC Machine Related Electronics
    Last Post: 02-10-2019, 07:44 AM
  3. Fanuc apc setting with linear scale, pls help
    By freemanxxx in forum Fanuc
    Last Post: 10-11-2013, 05:40 PM
  4. FANUC Linear Scale interface
    By gbowne1 in forum Fanuc
    Last Post: 02-05-2012, 04:44 AM
  5. How do you change a Fanuc 15M Linear Scale Interface
    By Mikeado in forum Uncategorised MetalWorking Machines
    Last Post: 09-29-2009, 05:43 PM
