504,353 active members
4,037 visitors online
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc OM alarm 310-320.. Axises need ZRN
Results 1 to 7 of 7
    Sep 2006
    13
    Question Fanuc OM alarm 310-320.. Axises need ZRN
    We have a CNC machine Tape drill OM system now have alarms
    310: x axis need ZRN... 320: y axis need ZRN..
    I dont know how I can remove the alarms
    when I try to move the axis to the home position (Refrence) the axis move until it hits the emegency swithes at the end of the axis stroke and machine will be off
    what is the ZRN ? and which parameters have to be set againe?
    Please help me
    Nov 2003
    98
    See my post in this thread for some useful parameters.
    http://www.cnczone.com/forums/showthread.php?t=40774
    Also, power machine down. Hold the following buttons P and CAN while powering maching back up. Hold them until machine is completely powered on. Move the axis to middle of travel then perform zero return. The P/Can tells the machine to ignore soft limits and allows it to home on limit switches.
    Bob
    Sep 2006
    13
    thanks bob
    The axises now can travel in MPG or Jog mode but the errors remain
    do you help me some fanuc documents about adjusting zero and refrencs in OM system?
    Super Moderator Al_The_Man's Avatar
    Dec 2003
    23161
    You most likely have battery back up position encoders, if they are disconnected then you lose the recorded position and you get 3x0 alarm ZRN is Zero Return.
    If you have the maintenance manual it shows in there how to record.
    If you need the manual in PDF send me a PM with a email address.
    Al.
    Albert E.
    Jan 2016
    7
    Re: Fanuc OM alarm 310-320.. Axises need ZRN
    Hello,
    I am having the same issue, Al I tried to send you a message but your mailbox is full , any chance that you put here the pages of the manual how to set the Zero?
    Cordially
    Francois
    May 2016
    365
    Francois is.your problem on a tape drill
    Jan 2016
    7
    Yes, even if it was sold under Stama brand, I finally managed to kill this alarm by changing the parameter to 22 (not so sure) from 011 to 111, it was enough
    Still if you have the full manual I would really appreciate if you can share it.
    Cordially
    Francois
  1. main part of the 4 axises cnc router machine
    By tinacnc in forum CNC Router Parts
    Last Post: 01-18-2014, 09:43 AM
  2. freezing when moving multiple axises
    By slowhitEJ1 in forum Automation Technology Products
    Last Post: 07-12-2013, 11:44 AM
  3. Replies: 6
    Last Post: 03-13-2013, 03:32 PM
  4. Sodick BF275 problem in axises
    By ehsan.amouzegar in forum General EDM Discussion
    Last Post: 02-07-2011, 04:18 PM
  5. Methods and apparatus for pre-planarizing cnc axises
    By eloid in forum CNC Wood Router Project Log
    Last Post: 02-27-2007, 04:35 AM
