542,198 active members*
3,286 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc OM-C option parameters # 900 ?
Page 1 of 2 12
Results 1 to 20 of 27
    Feb 2006
    211
    Exclamation Fanuc OM-C option parameters # 900 ?
    I have a VMC equiped with fanuc OM-C. It's Parameters got lost. Presently I looking for it's option parameters # 900. I have a backup of it's parameters but it does not contains 900 parameters. I would much appreciate for sending me option parameters along with every parameter bit description. Can I use Fanuc OM-D's 900 parameters instead of OM-C. Kindly help me to solve this problem.
    Community Moderator Al_The_Man's Avatar
    Dec 2003
    23687
    AFAIK the 900 options are the same for both, send me a PM with an email address.
    Al.
    Albert E.
    Jun 2007
    43
    For future reference, if you press and hold the EOB key, then press output/start, whilst outputting parameters, the 900 parameters will also be punched.
    Aug 2009
    12
    send me an email I will send you a pdf file for all the Fanuc OM C parameter
    Dec 2003
    23687
    Quote Originally Posted by Indmach View Post
    Hopefully he has it running after 5yrs? :drowning:
    Al.
    Albert E.
    i have hmc with fanuc omc. on screen x y z axis are display. but B axis is not display on screen. In B axis drive - is comming. In servo tuning menu B axis is not display. 8400 series also not display. i think B axis is by passed. can you pl guide me ?
    machineryclinic@gmail.com
    Somebody can send me the parameters for 4th axys !!! Pleaseeeeee
    Enviado desde mi GT-I9300 mediante Tapatalk
    Nov 2019
    4
    Smile Re: Fanuc OM-C option parameters # 900 ?
    Hello: I'm in need of 900 parameters for a FANUC OM-C controller also. It's a Mitsubishi gear hobber. Model G15CNC.
    Thank you in advance.
    Dec 2003
    23687
    Send PM with email
    Al.
    Albert E.
    Feb 2015
    4
    hello, i also need the 900 parameters for the OMC. Mine is the simple version with one cpu doing NC and PMC. theres no seperate PMC and Graphics card. Its a retrofit with no tool changer. I have the regular parameters but didnt know that extra buttons were needed for more parameters. I could also use an explaination of the Diagnostic parameters since those wernt backed up either. I guessed at some stuff and got the machine to home but many things dont work. Digital spindle is not talking to the control, single block wont turn off, tool unclamp non functional, and lube pump only works in manual mode. Ill PM my email for any info you can send my way. I called Fanuc and they said its all proprietary and they can send a teem to me to reprogram my machine. It didnt sound very economical.
    Dec 2003
    23687
    Sent
    Al.
    Albert E.
    Dec 2014
    33
    I also have a 0M-C that is acting strange. It won't allow me to edit any programs. The CAP soft key doesn't show up or the program list. I should be able to see the list of programs and hit "search" then the program number and input. At least that's how my other Miyano TSV's operate. This machine is new to me and someone may have tampered with the option parameters. Program protect key does toggle the correct bit. I have a 900 parameters list but there are a lot of blank spaces with no explanation. Any help would be greatly appreciated.
    Dear fellow enthusiasts I have a full backup of an OMC vmc Victor Vc 80, if anyone needs a copy, please ask!!
    Sep 2020
    5
    Alguien me puede enviar una copia del manual de parámetros 900 para un Fanuc OT
    Sep 2020
    5
    Quote Originally Posted by Al_The_Man View Post
    Send PM with email
    Al.
    Me puedes enviar los parámetros?
    Dec 2003
    23687
    See post #9 you have your private message shut off.
    Al
    Albert E.
  17. #17
    Sep 2020
    5
    Al
    No puedo enviarte, dice que has desactivado los PM
  18. #18
    Dec 2003
    23687
    Quote Originally Posted by vortech View Post
    No he desactivado el mío, pero el tuyo se muestra no activado
    Check your email
    Al.
    Albert E.
  19. #19
    Sep 2020
    5
    Gracias (y)
  20. #20
    Mar 2021
    4
    Hi bro,
    I need victor V center 80 om-c parameters
    It would be of great help.
Page 1 of 2 12
  1. Option parameters Fanuc 15T (1990)
    By richardfp4 in forum Fanuc
    Last Post: 05-02-2019, 01:32 PM
  2. Replies: 5
    Last Post: 10-13-2011, 04:15 AM
  3. Option Parameters Fanuc 180is-WB
    By NigelM in forum Community Club House
    Last Post: 07-13-2010, 12:18 PM
  4. Fanuc 18i MB option parameters
    By humpa in forum Fanuc
    Last Post: 08-01-2008, 04:51 PM
  5. Fanuc OM option parameters
    By allmetalcnc in forum Fanuc
    Last Post: 06-19-2008, 02:31 PM
