541,063 active members*
3,445 visitors online*
    Feb 2010
    22
    Fanuc OM PMC EPROM Memory failed
    Hello,
    I have big Problems with the PMC memory of my OKK PCV40. It is a Fanuc OM controller with its own PMC M module, on which the second Eprom "OF2" is defective. When reading this Eprom revealed that he has no more data stored. Unfortunately, I do not have the EProm data - does anyone have this data for me? Or can I find somewhere in the documents (printed listings I have)?
    So there is 3500kg scrap, i can crying... :-(
    Thanks for any help!
    Junior Member
    Aug 2009
    35
    Re: Fanuc OM PMC EPROM Memory failed
    If you find a working machine like yours and with the same controller OM, you can copy the two eproms. The PMC program listing should be in the documantation of your machine. What does the machine manufacture says?
    Aug 2018
    27
    one of my customer have the same machine
    please give me the exact reference wrinten on the eprom for check .
    if it's the same , i can make you an offer .
    regards
  1. Fanuc 11M EPROM Failure.
    By Harmeet in forum Fanuc
    Last Post: 05-19-2013, 09:17 PM
  2. Fanuc 10TF Eprom Damaged
    By Yazmo in forum Fanuc
    Last Post: 07-12-2011, 05:53 PM
  3. Fanuc Eprom
    By MysticMonkey in forum Fanuc
    Last Post: 11-24-2009, 10:26 AM
  4. Fanuc Eprom
    By gabedrummin in forum Fanuc
    Last Post: 06-06-2009, 10:26 AM
  5. FNC-5 memory module failed on back-up
    By laser2500 in forum German
    Last Post: 01-23-2009, 05:00 AM
