529,979 active members*
3,274 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Fanuc PS0128 Illegal Macro Sequence Number
Results 1 to 1 of 1
    Sep 2020
    Hi everyone,
    I keep getting this error when ever I try to use a GOTO command, I'm stripped everything else out and am just trying to run the code below to test it but it still throws the PS0128 error.
    Any ideas? It executes n02 correctly #704 changes to 1 but then is fails.
    N01(O028);
    N02#704=1;
    N03IF[#704EQ1]GOTO05;
    N04#705=1;
    N05#706=1;
    N06M30;
    N07%
    Apr 2011
    647
    Re: Fanuc PS0128 Illegal Macro Sequence Number
    Check for fat fingure mistakes. I ran this just as you have it on a 0iF with no issues.
    Sep 2018
    11
    One time I had a problem declaring subpgm like O00123 and calling them M98 P00123 instead of P123 ...
    try a GOTO5 instead of GOTO05
    Controllers are sometimes a bit picky on syntax !
