586,961 active members*
2,757 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc Spindle Servo and Amp Model 3
    Aug 2005
    128
    I retrofitted a machine and I am trying to get the spindle running. I am sending it the correct 0-10v and setup the inputs, but no spindle movement.
    Driver B-53425E, with A20B-1001-0120 spindle board and A20B-008-0030/050C orientation board
    Servo A06B-1003 B300
    servo readey setup:
    gnd to pin 47 CN1 ESTOP
    gnd to pin 7 CN1 MRDY READY
    gnd to [pin 45 CN1 SP Forward
    sent 0-10v to pin 31 VCMD-1 DA0 and gnd pin32 VCMD-2
    I hear the contactor in the drive when I send gnd to pin 47.
    Anyone have manual that shows wiring etc....?
    Any Ideas?
    Thanks in advance,
    Bob
    Aug 2005
    128
    Re: Fanuc Spindle Servo and Amp Model 3
    Problem regulated. Thanks
    Hello, could you tell me how you solved it?
    I bought a new control and wanted to use the servo spindle with its servo motor.
  1. Servo driver for Fanuc Model 5 servo motors
    By AlMolp in forum Servo Motors / Drives
    Last Post: 06-08-2014, 08:42 PM
  2. FANUC 3T MODEL C. SPINDLE DOESN`T START.
    By AntonioGlez in forum Fanuc
    Last Post: 11-20-2013, 01:06 AM
  3. Fanuc AC servo motor model 10
    By keyancnc in forum Servo Motors / Drives
    Last Post: 02-05-2012, 01:46 AM
  4. Fanuc Model 12 spindle problem
    By kalawa in forum Fanuc
    Last Post: 07-14-2010, 05:09 AM
  5. Help with FANUC 0i-Model A (servo parameters)
    By mr_electrician in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-29-2008, 07:28 PM
