601,639 active members*
2,866 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > FANUC system 6M Control - 402 servo alarm
Results 1 to 4 of 4
    Machine: Matra-Fanuc Tape Cut-Model Q. Control: Fanuc system 6M, Model B, Series ME
    First the Alarm 704 occurred that I dealt with for around a year. From time to time machine was in function.
    Then certain system alarms occurred.
    I cleared and initialized the bubble memory and input the parameters again.
    System alarms disappeared but new ones came: 402, 414, 424, 434, 454 and 704.
    Reset button removes all but 402 and 704.
    PRDY on velocity control units are off.
    My it be parameters issue?
    Any help would be much appreciated.
    Re: FANUC system 6M Control - 402 servo alarm
    Quote Originally Posted by smolly View Post
    If alarm 704 was a recurring problem before the memory reset,
    and it’s still present afterward, there might also be an intermittent hardware issue
    But still, the root issue now is likely software/configuration,
    since the spindle and servo drives aren’t even reaching the ready state.
    Many thanks for your replay.
    It looks like software issue for me, too, because servo alarms: 402, 414, 424, 434 and 454 occurred when I reset the bubble memory. But, I had original parameters at the machine and double checked if I had input them correctly and found no errors.
    I guess I first have to resolve servo alarms to get machine to the only 704 alarm status, like it was before I reset the memory.
    Any suggestion what to do next may be helpful.
    One more info.
    MCC contactor at velocity control unit does not turn on at all. I don't hear it any moment.
    Any idea what I have could done wrong?
