541,109 active members*
3,652 visitors online*
Thread: Feed Rate
Results 1 to 5 of 5
    Feb 2014
    36
    Feed Rate
    Two weeks ago today, I came into work to find the electricity had gone off during the night.
    The heater I use special for the machine had gone off, and not reset itself, that was the clue.
    It was cold, and the machine does not like cold !
    It lost all the parameters in the Micon. I re-entered them,,, and have rechecked them dozens of times now.
    Everything works except the program feed rate for cutting.
    The machine only responses to the manual feedrate controls on the Main Control Panel.
    I have tried M48 and M48 using MDI,, no luck.
    Any Ideas?
    Kindest regards,
    John
    Fanuc 15M
    HC400 machine
    Apr 2011
    738
    Re: Feed Rate
    Did you by chance also restore the PMC parameters?
    Feb 2014
    36
    Re: Feed Rate
    No, I do not know how to do them.
    Nov 2007
    194
    Re: Feed Rate
    Spindle command is G97 M3 S1000 and on the control its showing Ok for this ?
    Rapid is ok ?
    Dry run is not on ?
    Feb 2014
    36
    Re: Feed Rate
    I will try that in the morning.
  1. Steppers stall/oscillate at low feed rate. High feed is OK.
    By pfpmeijers in forum Stepper Motors / Drives
    Last Post: 02-17-2018, 07:12 PM
  2. feed rate vs override feed rate
    By Mooser in forum Tormach Personal CNC Mill
    Last Post: 08-16-2017, 09:26 AM
  3. feed rate and plunge rate help required please
    By curiosity22 in forum Australia, New Zealand Club House
    Last Post: 12-07-2015, 09:30 AM
  4. Feed rate Ovverride also Increases rapid rate.
    By Korellibopper in forum Machines running Mach Software
    Last Post: 01-31-2008, 12:37 AM
  5. Feed Rate and Spindle Rate for this cut?
    By DroopyPawn in forum General MetalWork Discussion
    Last Post: 11-22-2007, 06:12 AM
