535,468 active members*
3,217 visitors online*
    Mar 2007
    28
    File Format for RFQ Posting?
    What is the preferred file format for posting RFQ's to this group? I am designing an assembly in Solidworks 2011, and would like to float it to the community for prototype production. Thanks.
    -Tulsah
    Jul 2015
    18
    Re: File Format for RFQ Posting?
    You can post it in any format in this group... No problem at all...but it is better if you add igs and PDF files as well...
    Sent from my LG-V410 using Tapatalk
    Parasolids are the norm for 3D files out of Solidworks.
    Parasolids will retain the assembly structure when read in to softwares built on the parasolid kernel. (which is most 3D design softwares I've used)
  1. File Format
    By jrmach in forum BobCad-Cam
    Last Post: 04-10-2014, 07:26 AM
  2. What is the name of this file format?
    By owenransen in forum Uncategorised CAD Discussion
    Last Post: 02-28-2013, 05:39 PM
  3. WinNc 3.1 File Format
    By whiteredline in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2012, 05:02 PM
  4. Understanding file format
    By osaris in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-02-2007, 01:38 AM
