600,986 active members*
2,485 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > fixture not clamped on HAAS VF1 2006
    May 2019
    3
    Hello, i am new to cnc and have a used Haas vf1 2006, and get an error "fixture not clamped"
    the previous owner had an hydraulic clamp mounted, but it is no longer on the machine
    now, for homeing etc it shows this error alarm. I think it is M53 input. (goes to the connector where the clamp was connected)
    Is there a setting that i change? so it no longers looks at the M53 input?
    Bart
    May 2019
    3
    Re: fixture not clamped on HAAS VF1 2006
    Problem solved: parameter 278/2 "check pallet Input" set to 0
