589,420 active members*
4,926 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > FNC Control technique image missing
Results 1 to 4 of 4
    Mar 2024
    3
    Hello to all forum participants, I'm new here. I have a problem with the machine Cincinnati Milacron Arrow 750, its control system is FNC 5, after a power surge the power supply of the main computer failed, after repairing the power supply, there is an indication on the power supply itself and an indication on the memory module, they periodically turn on and off indicators. There is no image on the screen. I connect a standard LCD VGA monitor via cable. On the CRT (RGB) lines there is an incomprehensible signal with an amplitude of 50 millivolts. I have a question, how can I use the indication to track the state of the system? I also tried connecting 2 different PC Motherboard C20000 boards. In this case, none of the boards produces an image. Maybe someone has encountered such a problem and can tell me what I can do?
    I'm trying to start the FNC computer on the table; at the moment it is not connected to the machine.
    According to snippets of information from the forum, the causes of this problem may be in the memory module or in the main board, it’s strange that the behavior is the same with three different boards, there is no picture, the initial boot window does not appear.
    The original documentation does not contain initialization information regarding the FNC system. If anyone can share a CMOS firmware dump I would be very grateful.
    Mar 2008
    294
    Re: FNC Control technique image missing
    I would contact [email protected]; he was tech support on this product in the USA and may be of help to you.
    Mar 2024
    3
    Thank you for the advice.
    Mar 2024
    3
    Unfortunately the domain fivegroup.com it is for sale. Therefore, it is unlikely that I will be able to write to Robert.
  1. Inventor HSM Fanuc post processor v Cincinnati Arrow with CT FNC 4 control
    By Rathousekid in forum Autodesk Post Processors
    Last Post: 04-29-2018, 01:16 PM
  2. need help Arrow 500 FNC control
    By gronux in forum Cincinnati CNC
    Last Post: 02-08-2009, 04:56 PM
  3. Replacing the FNC-5 control unit
    By ltek in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-18-2008, 08:31 AM
  4. Control Technique Digitax DBE 750 AC Servo-Drive
    By GalaticDan in forum Servo Motors / Drives
    Last Post: 09-16-2005, 12:32 PM
  5. Control Techniques FNC-4 controller
    By rbrougha in forum Uncategorised MetalWorking Machines
    Last Post: 06-09-2004, 03:29 PM
