547,444 active members*
1,684 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Fuling inverter DZB300 or DZB200
Results 1 to 5 of 5
    May 2017
    16
    Hello buddies,
    I lost my fuling inverter DZB200 series because of uppervoltage (Electricity in Cameroon is a mess).
    I ordered a new one but the seller sent me a DZB300 series. Can I use it with my 1,5kw soindle ?
    If yes, how to set the parameters ?
    I count on your answer because I am afraid of any misuse.
    Thanks in advance
    Jan 2005
    12802
    Re: Fuling inverter DZB300 or DZB200
    Quote Originally Posted by bivegele View Post
    Hello buddies,
    Thanks in advance
    Sure if the VFD has a Kw Rating that suits your spindle, the old one most likely failed because of wrong Parameters set
    So if you have the VFD to Match the Spindle there will be no problem no matter what model the VFD Drive is
    Spindle spec's
    Kw 1.5
    Amps=??
    Hz=??
    Voltage=??
    VFD Drive spec's
    Voltage=
    Amps= output
    Mactec54
    Salut bivegele je suis au Cameroun et j’ai un problème avec mon inventer dzb300 je l’est configuré mais ma broche ne tourne pas. Comment faire?
    J’aimerai avoir ton numéro voici le mien +237699570073
    Mar 2009
    1648
    conect the motor directly without the inverter.
    Jan 2005
    12802
    Quote Originally Posted by Algirdas View Post
    How could you post such a thing without knowing the motor spec's
    Mactec54
  1. Fuling Inverter DZBSeries
    By gerardo.pellice in forum Stepper Motors / Drives
    Last Post: 09-03-2014, 09:15 AM
  2. Replies: 0
    Last Post: 08-28-2014, 01:51 AM
  3. SEtting Fuling DBZ200 Inverter
    By regpugh in forum DeskCNC Controller Board
    Last Post: 03-28-2014, 11:51 AM
  4. Fuling Inverter spindle speeds and feed rates
    By alanstclair in forum Chinese Machines
    Last Post: 07-17-2012, 11:21 PM
