562,272 active members*
2,574 visitors online*
IndustryArena Forum > WoodWorking > General WoodWorking > Full Panel Dust Extraction
Results 1 to 5 of 5
    Jun 2008
    27
    I have been doing a lot of cabinet panels cuts on a CNC with a vacuum. Most cuts are with a 3/8 compression bit doing full passes in 3/4 plywood. For my dust collection, I have to cut the port by about 1/2 or it is too strong and will suck the bristles inside.
    Cleaning up the bed between passes is still fairly time consuming as there is just too much to blow off with an air hose. Just trying to gauge whether cleaning up a lot between sheet is typical or if there is something wrong in my setup? Any tips / tricks?
    Apr 2004
    5577
    Re: Full Panel Dust Extraction
    If you've got vacuum pressure to spare in your dust collection system, why not position an air nozzle inside the dust bonnet to blast chips out of the groove?
    Andrew Werby
    Website
    Jun 2008
    27
    Yea - I should have known that. Every time I have seen a nozzle setup, I just think misting coolant, but this makes just as much sense. Thanks!
    Jul 2018
    4470
    Jun 2008
    27
    @peteeng - very cool - thanks for sharing
  1. DUST EXTRACTION HEAD
    By SIGNMAD in forum Excitech routers
    Last Post: 11-27-2008, 08:15 AM
  2. Dust extraction - ducting and noise
    By sploo in forum Safety Zone
    Last Post: 04-02-2007, 08:03 PM
  3. Dust Extraction Sale
    By diarmaid in forum Safety Zone
    Last Post: 09-19-2006, 05:36 AM
  4. Dust Extraction on PTP Routers
    By Scrit in forum CNC Machining Centers
    Last Post: 09-21-2005, 04:52 PM
