548,315 active members*
2,230 visitors online*
    Mar 2019
    10
    Fusion 360 Post
    Hi all,
    First I just want to thank everyone who posts here - this has been an amazing help while I get my new to me Milltronics mill up and running.
    Now my question -
    for any Fusion 360 Users - are we just using the stock Fusion Milling post or is there a better post floating around?
    I have a Cent6 Controller on a 2002 vintage MB-11 Mill (no tool changer)
    Coming from a Small mill/Mach 3 background and that post has always been very reliable right from fusion.
    Cheers
    Eric
    Mar 2019
    31
    Re: Fusion 360 Post
    I've been using a "stock" one from a few years ago. I haven't tried the latest one because I have modified the stock one to suit a few preferences of mine. I have a partner 1 and the stock one turns the coolant on at tool change height which can make quite a mess when running a larger facemill. I have it to where the coolant comes on at the clearance plane. There's a few other tweaks I have done also. The stock one should get you going though. There is a manual out there on the web from autodesk that tells how to do post modifications also.
    Sent from my SM-N960U using Tapatalk
    Mar 2019
    10
    Re: Fusion 360 Post
    Chris,
    Thanks for the reply!
    I will watch out for the coolant issue for sure. I will mostly be dry cutting or using mister so it shouldn't be too much of an issue but you never know.
    Cheers
    EE
  1. Dynatorch post for Fusion 360?
    By forhire in forum DynaTorch
    Last Post: 07-16-2020, 03:11 AM
  2. Fusion 360 post for Bridgeport DX-32.
    By forhire in forum Bridgeport / Hardinge Mills
    Last Post: 02-24-2020, 02:31 PM
  3. Need a post for Fusion 360
    By cncadmin in forum Screen Layouts, Post Processors & Misc
    Last Post: 07-11-2017, 05:32 AM
  4. fusion 360 post?
    By mikethemachine in forum Post Processor Files
    Last Post: 05-23-2016, 06:01 PM
  5. Fusion 360 Post
    By wildwhl in forum Tormach Personal CNC Mill
    Last Post: 08-27-2015, 05:10 AM
