Hello
what Post Process use for planetcnc in Fusion360....??
I use this below on Autodesk page.... but doesn't work ...bunch of errors an Q errors....
Any suggestions???
Hello
Any suggestions???
I am using version 43323 with some adjustement, works perfect.
Hi there
I’ll be able to help you edit the post so it works correctly with PlanetCNC.
I specialise in developing post processors for fusion and it should be fairly straight forward to resolve. Please email me at [email protected]
Michael
Set the smoothing in the post processor from G64 with PQ to G64
I can share but, be aware that there is some pin-out used which can be diferent than yours...
[email protected] moze na email....
jer nemogu vam poslati privatnu poruku blokirali ste primanje
hmmm, I'll will check that
and I did, nothing wrong or blocked. Did you recive my PM?
Get stock one from fusion works if you set the smoothing parameters right
hm
there must be something with server....
I got this err when trying to modify my profile:
403 No access
There was an unexpected server error.
Same issue. I've to remove the line with "Q" command every time.
As I sad before, there is certain command that ONLY suits my cnc.
"Q" "x" is an output which I use for my cnc, you need it or not....
There is an option when generating nc file, check box wit dust suction and vacuum can be enable or disable. That generates lines with "Q" in.
Hope it helps....
Ok, sorry my mistake.
I think that @ddrulez point you to proper thing. When making NC program, take a look to pull down menue where is written "G64 PQ..." something and CHANGE it to G64 ONLY.
Attachment 501522
The PlanetCnc post on Fusion 360, ends the program with:
M30
But It looks like you leave the spindle on, so I add M5 line on every file.
Someone has encountered the same issue?
