585,996 active members*
4,544 visitors online*
Results 1 to 16 of 16
    Oct 2014
    15
    G and M codes
    I'm looking for a complete list of G and M codes for an okuma osp 7000l with dual turrets
    Feb 2005
    69
    Re: G and M codes
    PM sent.
    Sep 2014
    18
    Re: G and M codes
    Have you tried OKUMA manuals or technical support. Thanks FISHINGUY.
    Aug 2011
    2517
    Re: G and M codes
    erm, yeah. All of the G/M codes are in the back of any Okuma OSP-7000 Programming Manual......
    Oct 2014
    15
    Re: G and M codes
    Erm yeah wouldn't be asking for them if I had them.
    Sep 2014
    18
    Re: G and M codes
    There should be complete list on most software support indexes, when I was in school I could request them from any machine tool manufacturer, they would always send as much information as I needed. Thanks FISHINGUY.
    Oct 2014
    15
    Re: G and M codes
    Thanks for the help
    Aug 2011
    2517
    Re: G and M codes
    you could google and get a big list....
    Okuma Lathe G M codes G-codes M-codes
    Anyway, see attached. This is from the back of the programming manual.
    Attached Thumbnails Attached Thumbnails Okuma_GM_Codes.pdf
    Sep 2014
    18
    Re: G and M codes
    Looks like a good list, store this in my bookmarks, make copies.
    Oct 2014
    15
    Re: G and M codes
    Quote Originally Posted by Factory Guy View Post
    PM sent.
    Does the okuma impact lu 35 with okuma osp 7000l have a relative position screen similar to the fanuc control panel.
    Mar 2009
    1982
    Re: G and M codes
    yes, Okuma OSP 7000L can show relative position
    can't tell how similar it is. X= Z= for sure
    Oct 2014
    15
    Re: G and M codes
    Do you use the actual position screen or the graphics screen?
    Aug 2011
    2517
    Re: G and M codes
    there's no relative position screen on Okuma OSP-7000.
    You have to do stupid things like set the readout to 0 using ZERO SHIFT on the zero-set screen but if you press reset the position goes back to where it was. There is no equivalent relative position screen on OSP-7000. There are also no wear offsets. Great, isn't it....... ;-)
    Oct 2014
    15
    Re: G and M codes
    are we talking about the same osp 7000l???
    Oct 2014
    15
    Re: G and M codes
    I'm trying to find a easier way to do a jaw setup without doing so much math. Lol
    Aug 2011
    2517
    Re: G and M codes
    well i'm talking about my piece of crap LT with OSP7000. Not sure what options yours has. The manual has no mention of a relative position so there is no relative screen showing U or W. not sure why Algirdas said it has one, he is probably trying to hide the fact that the controller lacks basic functionality that Fanuc had back in 1978 ;-)
    what I do for jaws is call up a pre-set boring bar in MDI, move it to a size I need then press reset, look at the X/Z and use that as a reference.
    Lets say I want to bore the jaws 2.5" diameter by 1" deep.
    for this method the Z workshift can be anywhere or not set it doesnt matter.
    In MDI I type...
    G0 T0101 [WRITE] [START]
    the turret will index but XZ will not move
    G0 X2.5 Z1.0 [WRITE] [START]
    The tool moves to the correct finish diameter and to Z1.0 in relation to the work zero (which is not necessarily correct for this set-up)
    I press reset there. The X and Z goes back to some other sizes.
    Say X is 3.5678 and just ignore Z. the X shown on the readout is one of my reference numbers.
    I write down the X value and that is my finish size.
    I start the chuck and touch the face of the jaws and write down the Z value.
    say it is Z6.9345
    Now I subtract 1" off the size and write that number down. that is my finish depth.... Z5.9345
    So now I have my finish X diameter and finish Z depth. X3.5678 Z5.9345
    Now just bore the jaws out manually and use those 2 numbers as the final sizes.
    Alternatively if the tool is set, re-set the work zero to the face of the jaws and write a small roughing cycle with G85+G81 and G87 so the tool cuts your exact jaw size required. you can keep that program in the machine permanently and use it whenever you need to bore the jaws.
    If you want to use the Zero Offset function, touch the tool on a known diameter or face, go to the ZERO SET screen, move the cursor to ZERO OFFSET in either X or Z, press CAL and type the known position and press WRITE.
    The readout will change to your proper size so the tool will cut size but if you press reset the size will go back to the original position. if you moved the tool away, press reset then need to go back in again and take another cut you must go back to the ZERO SET screen, move the tool to a known position and re-calibrate the ZERO OFFSET (which is a real pain in the ass).
    but then again so is everything Okuma so it's par for the course.
  1. G codes and M codes for Mazak Quick Turn T-2
    By sauli in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-23-2011, 05:22 PM
  2. G codes M codes Mach3
    By eaglezsoar in forum Mach Software (ArtSoft software)
    Last Post: 02-04-2011, 12:38 AM
  3. Need full list of G CODES AND M CODES FOR FANUC 21I
    By SonnyTees.com in forum G-Code Programing
    Last Post: 02-23-2010, 05:27 PM
  4. M CODES AND G52
    By fenix728 in forum G-Code Programing
    Last Post: 11-18-2008, 03:03 AM
  5. M-codes and G-codes 4 Matsuura ES-1000V
    By maximusek in forum G-Code Programing
    Last Post: 11-27-2007, 01:41 PM
