535,633 active members*
4,035 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > G0704 Motor Troubleshooting, replacement suggestions
    Mar 2012
    227
    Having issues with the motor, yah I know, the originals suck!!!
    It stalls, at least to me, pretty easy, it popped the fuse, just seems like the motor isn't even working hard.
    I checked the temp on the motor, it's at 100*F, that's about 30*f over ambient, or the table of the machine. That was when I was using a carbide 1.750" holesaw in 1.75"x.120" wall square tube. The Delta 1/2hp drill press will rip through that. Just seems if it was the motor, it would be getting pretty hot before popping the fuse??? Maybe the power supply is weak? Any advantage to swapping in a KBIC board in there???
    Anyway, any fairly easy, fairly inexpensive alternatives???
    Thanks,
    CR
    Mar 2012
    227
    Re: G0704 Motor Troubleshooting, replacement suggestions
    Well, investigated a little more, found one of the brushes making contact about 1/2 way? Does look like it had much use and probably wasn't broken in correctly, I got up to forward at 1000rpm, motor was warm, getting late.
    Going to follow up today with some more break in, see if I can get that brush fully seated. I'm thinking if it's not, I'm not getting full current to the commutator...
    CR
    Dec 2020
    Looks like the brush wasn't seated correctly, fully seating it should help. If it doesn't it's time for a replacement.
  1. G0704 motor replacement
    By taiwanluthiers in forum Benchtop Machines
    Last Post: 11-12-2016, 07:27 AM
  2. Replacement brushes for G0704 stock motor
    By Semus in forum Benchtop Machines
    Last Post: 01-04-2016, 06:39 PM
  3. Recommend a replacement spindle motor for G0704
    By dalee100 in forum Benchtop Machines
    Last Post: 06-29-2013, 03:00 AM
  4. G0704 Motor replacement
    By RX-Heven in forum Benchtop Machines
    Last Post: 04-08-2011, 01:34 AM
