567,673 active members*
2,969 visitors online*
Results 1 to 1 of 1
    Oct 2005
    1142
    G38 Probing array
    Here are a couple of probing routines that log the trip points as it probes an array. There are 2 programs an interior and an exterior. They are completly tunable. You can point them in a direction and limit the width of teh arrray up to 360 degs. You can also set the start point and the width in degs.
    You can adjust the parameters of the array by editing the Paramaters at the beginning of the file.
    (;-)TP
    Attached Files Attached Files
  1. SmartProbe.ngc / G38.4 not working
    By sopac in forum LinuxCNC (formerly EMC2)
    Last Post: 04-02-2011, 11:59 PM
  2. Pin array
    By sp1nm0nkey in forum Mastercam
    Last Post: 07-05-2009, 03:27 AM
  3. Undrestanding G38.2 probe file output
    By bogflap in forum LinuxCNC (formerly EMC2)
    Last Post: 03-05-2009, 03:43 PM
  4. G38 Rectangular pattern probs
    By Lugy in forum G-Code Programing
    Last Post: 09-22-2008, 09:31 AM
  5. Array with v20
    By DEW in forum BobCad-Cam
    Last Post: 11-21-2007, 12:50 AM
