Mariss,
I am researching how to use the Hamlin 55110-3H-02-A Hall Effect Senors as honing switches. Thinking this post would lead to the answer my question, I also Googled "APS4-12s-e-d" to follow your discussion. The "APS4-12s-e-d" has three wires like the "55110-3H-02-A". What did you mean by term 1,3 & 4? In my plan, I connect the "55110-3H-02-A" Blue wire to G540 input 1, 2, 3, or 4. Using a combination of resistors (
Voltage Divider Calculator) to reduce the 48 volt input to 12 volts on the Red wire and the GND to the Black wire. Do you or any one else see a problem with this?
