585,942 active members*
3,385 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller & Computer Solutions > G540 / UC100 Controller Build for GenMitsu 3018 routers
Results 1 to 5 of 5
    Dec 2020
    7
    Question G540 / UC100 Controller Build for GenMitsu 3018 routers
    I've had very good luck with my Genmitsu 3018 ProVer MX3. However, I'm not particularly enthusiastic about the Mach3 controller solution... I also have the GRBL controller for the 3018 but that's not the direction I want to be moving.
    I'ld like to build a controller solution for my 3018 based on the G540 and a UC100 so I have maximum flexibility and can use it with all three major Win10 software controller solutions (Mach3, Mach4, UCCNC). This is more about ME than the ROUTER itself.
    I know to some (most!) folks, this might seem overkill for a little $350 3018, but I expect the electronics/controller might very well be migrated fwd into a larger more capable platform at some point in my future.
    I'm pretty sure I have most of the pieces figured out. (This includes a 24V power supply to feed the 12v-24V 775 spindle and a 10A 0-10V "LED PWM dimmer" to function as its speed control).
    However, if anyone has any past experience or input on this project I'ld be interested in whatever suggestions might be provided.
    Thanks!
    Mar 2003
    35538
    Re: G540 / UC100 Controller Build for GenMitsu 3018 routers
    Get a UC400ETH instead of the UC100. It's more powerful, more expandable, and has much better noise immunity than a UC100, for only about $25 more.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2020
    7
    Noted.
    Will it plug directly into the G540? IOW: Is there a readily available cable to go from the UC400ETH to the G540?
    Mar 2003
    35538
    Gerry
    Nov 2007
    616
    Quote Originally Posted by evanevery View Post
    Thanks!
    Evan, did you ever do anything with this project? I also recently picked up a 3018 and already upgraded the gantry using 12mm linear rails. I also happen to have an unused G540 and UC100 controller just gathering dust on a shelf. I've been thinking about adding these to the 3018. I do like the little Genmitsu GRBL controller, but think the G540 would make it a much more robust machine.
    <a href="http://www.cnczone.com/forums/mini-lathe/82871-7-x-10-project-started.html" target="_blank">7X10 Lathe conversion</a>
    <a href="http://www.cnczone.com/forums/open-source-cnc-machine-designs/335846-cnc.html" target="_blank">Custom X-Carve router</a>
    <a href="http://www.linkedin.com/in/tooldesign" target="_blank">LinkedIn</a>
  1. UC100 controller
    By pjf610 in forum Chinese Machines
    Last Post: 04-08-2020, 09:29 PM
  2. Has anyone setup g540 with 5axis with a UC100 can it be done? Alternately a anaxbb-e?
    By curiosity22 in forum Australia, New Zealand Club House
    Last Post: 04-23-2019, 12:00 PM
  3. Replies: 15
    Last Post: 01-18-2017, 05:10 PM
  4. UC100 w. G540
    By WORM6842 in forum ArtCam Pro
    Last Post: 09-06-2013, 04:07 AM
  5. G540 with UC100 USB connection
    By automationtechinc in forum Stepper Motors / Drives
    Last Post: 05-05-2013, 06:04 PM
