585,994 active members*
4,600 visitors online*
Thread: g71 type 2
Results 1 to 14 of 14
    Aug 2010
    g71 type 2
    I am trying to use a g71 to rough an internal profile with an undercut. The problem is it wants to do the undercut with 1 cut. I am wondering how I can do this with a g71 type 2? I have never tried it and I am wondering how to get it working.
    thanks in advance
    Aug 2010
    sorry it is a fanuc 16t control
    Mar 2003
    2932
    Post your program here.
    Feb 2006
    1792
    Specify both X and Z in the P-block, for type II operation.
    Aug 2010
    I will post the program when I get back to the shop. what do you mean post the x and z on the p line?
    Mar 2003
    2932
    Quote Originally Posted by derek68 View Post
    G71 P101 Q102 ...
    N101 G00 Xnnn.nnnn Znnn.nnnn (P-BLOCK) <--- programming X AND Z in this block specifies Type II roughing cycle.
    N102 (Q-BLOCK)
    Aug 2010
    I will try it out on monday and let you know. thanks for the help
    Aug 2010
    here is the program I am still unsure about the p line
    g00g28u0w0
    n10g54t1111
    g96s300m04
    g00x2.00z.100
    m08
    g71u.100r.050
    g71p20q30u-.025w.025f.010
    n20g00x3.780
    g01x0.0f.010
    g01x3.52z-.130
    z-.658
    g03x3.395z-.720r.062
    g01x3.1
    z-.970
    x3.500z-2.00
    z-3.5
    x2.2z-5.75
    z-7
    n30
    g70p20q30
    Aug 2010
    I figured it out. I had to change a parameter in the controler and everything seems to be working fine.
    Feb 2006
    1792
    I doubt.
    Aug 2010
    I put the x and z on the p line and i was getting an error no matter what I did. I then was told that I had to change a parameter to be able to use a type 2 roughing cycle on a controler from the mid 90s. I changed the parameter and put the x and z on the same line and now it works
    Feb 2006
    1792
    g01x0.0f.010
    Have you typed this line correctly?
    Aug 2010
    z0
    Sep 2005
    273
    What parameter did you change, im having the same problem
  1. G71/G72 type I vs. type II cycles
    By sinha_nsit in forum Fanuc
    Last Post: 08-28-2010, 11:20 AM
  2. What Type of CNC to get??
    By FUBAR62172 in forum Community Club House
    Last Post: 06-27-2009, 01:47 AM
  3. G71 type I and type II cycles
    Last Post: 11-03-2008, 12:34 PM
  4. What type of oil to use
    By Grego in forum Shopmaster/Shoptask
    Last Post: 12-22-2007, 08:55 PM
  5. what type of CNC do I need?
    By Goldhunter_2 in forum Mechanical Calculations/Engineering Design
    Last Post: 06-25-2005, 04:57 AM
