585,589 active members*
2,866 visitors online*
Results 1 to 4 of 4
    May 2008
    14
    Unhappy G75 GROOVING CYCLE
    Dear All
    kindly help me out in the grooving cycle programming with g75 with detailed explanation
    i want to machine a groove of
    width 8mm
    distance from face of the job 16mm
    groove radial depth 1.75mm
    insert width 3mm
    system fanuc oi mate
    kindly reply asap
    rgds
    Girish
    Feb 2006
    1792
    OD is also needed.
    Say, it is 20 mm dia.
    Use the lower left corner of the insert as the reference point of the tool.
    G00 X22 Z1;
    Z-19;
    G01 X20.5 F10;
    G75 R.2; (radial retraction in mm after each peck)
    G75 X18.25 Z-24 P1000 Q2500 F10;
    (X18.25 Z-24) is the lower left corner of the groove,
    Peck length is 1 mm,
    Lateral shift is 2.5 mm,
    Feed is 10 mm/min (with G98).
    If you are serious about CNC programming, you must have a personal copy of a programming book. You will find many answers there.
    Edit: Replace X18.25 by X16.5 for 1.75 mm depth
    harshal Guest
    Re: G75 GROOVING CYCLE
    G75 FANUC CANNED CYCLE GROOVING CNC PROGRAM ..EXAMPLE visit CNC PROGRAMMING TUTORIAL
    04521
    N10 G90 G21 G99 F0.15 ;
    N20 G50 S1500 ;
    N30 M06 T01 01 ;
    N40 M03 G96 S300 ; CNC PROGRAMMING TUTORIAL
    N50 M08 ;
    N60 G00 X57 Z-40 ;
    N70 G75 R1 ;
    N80 G75 X35 Z-60 P3000 Q9000 ;
    N90 G00 X60 ;
    N100 G28 U0 W0 ;
    N110 M05 M30 ;
    harshal Guest
    FANUC G75 CANNED CYCLE GROOVING CNC PROGRAM WITH description - CNC PROGRAMMING TUTORIAL
    01451
    N20 G50 S1500 ;
    N30 M06 T01 01 ;
    N40 M03 G96 S300 ;
    N50 G00 X52 Z-10 ;
    N60 G75 R1 ;
    N70 G75 X30 Z-30 P3000 Q20000 ;
    N80 G00 X60 ;
    N90 G28 U0 W0 ;
    N100 M05 M30 ;
  1. grooving cycle
    By mr_campbell in forum Fanuc
    Last Post: 05-27-2013, 09:24 PM
  2. CYCLE 83: pecking cycle with deepened starting point
    By Bastida in forum SIEMENS -> GENERAL
    Last Post: 12-18-2011, 04:25 PM
  3. fagor 8055t grooving cycle offset problem
    By jro in forum Fagor Automation
    Last Post: 12-13-2010, 08:41 PM
  4. Grooving HELP!
    By modeltruckshop@ in forum Uncategorised MetalWorking Machines
    Last Post: 04-23-2009, 02:49 AM
  5. Fanuc G75 Grooving Cycle post processor
    By rk176 in forum FeatureCAM CAD/CAM
    Last Post: 11-07-2006, 02:00 PM
