504,500 active members
3,452 visitors online
Results 1 to 7 of 7
    Jul 2003
    1671
    Galil d300 interface board
    Can anyone identify this? I would like to find a replacement - but my searches are coming up empty. It looks like a 4 axis breakout board and is connected to the dmc-1840 pci card...
    Re: Galil d300 interface board
    I have been working with Galil products for over 20 years and this is the first time I have heard of a D300 breakout, nor can I find any information on it. It may have been a special device built specifically for an OEM. You might check with Galil, they may be able to provide one, but they may direct you to the OEM. Galil Motion Control
    This is what I use for a breakouts, the listing is about 1/2 retail price. https://www.ebay.com/itm/PHOENIX-CON...IAAOSwihxc9Y8M
    But the above breakout may require a relay interface to use the 5V outputs. The ICM-1900-OPTO might be a direct replacement. In either case you would need a 100 pin cable.
    This might be worth a look. https://www.ebay.com/itm/Galil-DMC-1...EAAOSwUuNctn40
    I don't think the above has the -OPTO option, but not sure. But you get the cable and a DMC-1840 as a bonus, pretty good deal.
    Jim Dawson
    Sandy, Oregon, USA
    Jul 2003
    1671
    Well poop!
    I had found the second ebay one - and it might work in a pinch. Will have to do some research.
    Thanks much - I will call Galil...
    sam
    Super Moderator Al_The_Man's Avatar
    Dec 2003
    23162
    I have never seen that version either.
    I do have some old surplus Galil break out boards, one does not have a number, it has the I/O and encoder feedback inputs with LED indicators.Has IDC sockets and several 8 and 16 terminal breakouts.
    The other is a ICM-1100/AMP-1140.
    I also designed and made up our own version as we used to originally use the now Legacy DMC-1000 boards extensively.
    Al.
    Albert E.
    Jul 2003
    1671
    I contacted galil US and they said that they thought it was a model from their Denmark division..
    The Denmark location says that they don't have any and it is obsolete..
    Back to square one.
    Dec 2003
    23162
    What is wrong with the original, maybe fixable, if there is a problem.
    Usually there is not a lot to them.
    Al.
    Albert E.
    Jul 2003
    1671
    I have not been in it yet. You may be right. I was told when one of the tech was here a few years ago - he pulled it out and soldered a bunch of joints.. It has been running so we haven't had a chance to pull it out.
    It is very flakey - stuff stops working - wiggle/replug connectors and it starts working again.
    sam
    Quote Originally Posted by Al_The_Man View Post
    Al.
  1. USB I/O Interface Board
    By Tony T in forum Tormach Personal CNC Mill
    Last Post: 01-30-2017, 11:16 AM
  2. BREAKOUT BOARD INTERFACE BUFFER BOARD
    By deslee in forum Servo Motors / Drives
    Last Post: 08-17-2014, 07:32 PM
  3. D300 to 600
    By CNC Machine OT in forum Fanuc
    Last Post: 08-10-2013, 01:45 AM
  4. Interface board Rodgers board/ Romaxx Encoder Interface.
    By Ark1 in forum Wood Lathes / Mills
    Last Post: 03-23-2013, 10:57 PM
  5. Gecko to Galil ICM-2900 Break out board
    By smi4motion in forum Gecko Drives
    Last Post: 10-07-2005, 04:25 PM
