554,328 active members*
1,933 visitors online*
Results 1 to 7 of 7
    Aug 2018
    29
    Gantry - Rigidity V. Weight
    Early stages of designing a machine that will handle 4X8 material so the approx dims I'm playing with are 6X10.
    In pursuit of a rigid 6' gantry, I've noticed it's probably becoming fairly heavy and am wondering what the limits are
    for a couple of large nema 34's. I haven't got anything on paper but just licking my thumb, checking the wind, I'd
    say I'm between 400-500 lbs. Trying to use a lot of material I already have.... 1" T6 plate may be aluminum but it's
    still heavy as hell and structural steel not much better. Would appreciate your thoughts on what the limits are and
    what to watch out for.
    thanks
    cncneon
    Apr 2004
    5539
    Re: Gantry - Rigidity V. Weight
    At that point, you might want to make it a fixed bridge and move the table instead.
    Andrew Werby
    Website
    Jan 2005
    14310
    Quote Originally Posted by awerby View Post
    10' moving table the machine would be near or over 20' long
    Mactec54
    Jul 2018
    4200
    Hi Neon - The gantry is not being lifted so it can be moved by small motors. Its the same as you can push your 1 tonne car around in a flat carpark. The issue is what acceleration do you want to achieve? If a hobby machine then modest accelerations can be achieved using nema23s and a fine ballscrew pitch. So theres a Q? is this ballscrew or R&P? The usual design workflow is to complete your structural design. Then you know the weight of everything. Then you can design your motion systems. Hiwin publish all the formulas needed for this... Peter
    Nov 2013
    2021
    as an example of what Peteeng is talking about: I have cast iron axis beds of 115kg each, moved by 32mm diameter 5mm pitch screws with 750W servos.
    You'd think that the main inertia would be the 115kg piece of cast iron, in fact I allowed a bit extra for the vice etc, say 150kg......but you'd be wrong. When you do the calculation 80% of the
    inertia is in the rotating steel ballscrew, 12.5% in the armature of the servo and only 7.5% in the 150kg axis mass. The acceleration of the axis is then determined by the ballscrew rather than the
    weight of the axis. It sounds counter-intuitive but the calculations don't lie. If you use fine pitch, say 5mm or less, ballscrews then the acceleration will be determined largely by the ratio of the ballscrew
    inertia to the torque of the stepper....and the mass of the gantry probably quite small influence.
    Craig
    Jul 2018
    4200
    Hi All - seems the Zone has hiccups at the moment. Lots of repeat entries... Peter
  1. Fixed gantry or column for mill rigidity?
    By JRoque in forum Uncategorised MetalWorking Machines
    Last Post: 04-23-2021, 04:10 PM
  2. Classic Gantry Side vs. Extended Profile rigidity
    By Blazedazer in forum Mechanical Calculations/Engineering Design
    Last Post: 09-21-2017, 01:52 PM
  3. Cost to rigidity balance... where is it? Need help planning large gantry.
    By Jeff0000 in forum DIY CNC Router Table Machines
    Last Post: 11-08-2016, 10:21 PM
  4. Gantry Weight
    By assadi in forum Mechanical Calculations/Engineering Design
    Last Post: 02-26-2015, 01:27 AM
  5. Gantry rigidity question
    By mcv300 in forum General Waterjet
    Last Post: 07-14-2011, 03:11 AM
