504,413 active members
5,008 visitors online
IndustryArena Forum > Other Machines > PCB milling > GBR Candle - Heightmap checkbox disabled, why?
    Oct 2018
    3
    Hi!
    I'm new here on this forum and in the world of cnc stuff.
    I bought a diy cnc machine from China.
    The DIY 2418 machine, I wish to use it to make my prototype pcb at home before I send it out to
    make professional pcb's...
    For creating the pcb I use the NI Ultiboard software.
    For generating the gcode I use the Flatcam software.
    I use the GRBL Candle software to send out the gcode.
    Everything is fine jut a few things are making me crazy!
    1. In Ultiboard I can't export the excellon drill file but I can export a drill .gbr file.
    How can I use this gbr file for drilling my pcb ?
    2. In the Candle software, there is a "Heightmap" option.
    This option is working well, but I don't know is it enough just to measure the
    PCB deviation with the Heightmap option and just send out the gcode?
    Or I have to do some other tasks with the Heightmap result before I send out the gcode?
    There is also a checkbox in the Heightmap window "Use Heightmap" but this is non-stop gray - disabled.
    Will this function automatically correct the Z depth when I try to mill my pcb after I measured the surface
    deviation?
    What I doing wrong?
    Thanks.
    Jul 2019
    4
    Re: GBR Candle - Heightmap checkbox disabled, why?
    Hi in the software for the height map, you need to make sure that there is a circuit upload first, then it will be available. I have a CNC 1610 and it uses grbl the same program, I was not able to use heightmap because there was no circuit to z-prob. Check out my YouTube video to see how I made a PCB, including heightmap/z-probing.
    This is the link to the video: https://bit.ly/2G9fo9l
    I will make a tutorial soon
  1. Is it feasible to cut out letters from candle wax?
    By toeknee01 in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 08-05-2015, 04:54 AM
  2. G41 & G42 are disabled
    By hadi-nour in forum Fanuc
    Last Post: 07-15-2015, 07:54 PM
  3. Replies: 1
    Last Post: 01-28-2015, 05:25 PM
  4. raster (full heightmap) to vector, recommendations
    By subatomic in forum Uncategorised CAM Discussion
    Last Post: 05-09-2009, 08:50 AM
  5. Candle cutting
    By interflexo in forum General Material Machining Solutions
    Last Post: 01-15-2007, 10:45 AM
