562,378 active members*
3,472 visitors online*
    Aug 2003
    9
    Gear hobbing!
    Hi!
    I want to do gear hobbing and wonder if there is a possibility to do synchronization of two axis in CNCUSB or TNG? Using signals from encoder on each axis.
    Regards
    Gunnar
    Moderator
    Mar 2017
    1077
    Re: Gear hobbing!
    Axes are synchronized between each other. There is no need for second encoder.
    Gear hobbing is very similar to threading. Unless I'm missing something it should work fine.
    Apr 2016
    17
    Re: Gear hobbing!
    This is now a question on PM.
    The question is the feed rate in x,y,z,u synched to spindle encoder? If the spindle bogs at all the axis need to stay in exact timing. E-gearing is another term used for this sync. Concept is very close to threading cycle.
  1. gear hobbing
    By KERKENIANES in forum General MetalWork Discussion
    Last Post: 08-29-2016, 04:34 PM
  2. Gear hobbing
    By Dooda in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-16-2009, 03:54 PM
  3. gear hobbing....
    By Chris D in forum General MetalWork Discussion
    Last Post: 02-27-2009, 08:41 AM
  4. Gear hobbing on a VMC
    By dcoupar in forum Fanuc
    Last Post: 09-11-2007, 10:11 PM
  5. gear hobbing on mach3
    By rasta in forum Mach Wizards, Macros, & Addons
    Last Post: 07-30-2007, 12:56 PM
